kyle26nluvnit
- May 30, 2010
- 3
I recently purchased a 95 aluminum tracker bass boat and it has a 60hp mariner 2 stroke # 0G225570. I know from previous boats i have owned that there is a problem with the cooling system on the engine. Right now the engine starts up great everytime you turn the key, but the coolant passage on the back is only dribbling water instead of squirting it out. I have found the parts online but before i order them i was wondering if anyone can provide me with a diagram of the system so i can make sure its not just clogged. I had another boat that did the same thing and it was only because of a mud dobber nest the pump did not need to be replaced. any help is greatly appreciated
