nonninator
- Aug 30, 2009
- 19
I have a 150 V6 2 stroke merc Salt water..its a 98..It will start fine..idle fine...but once I put it in the water i can't even back off the trailer...it dies with anything past clutch..I have replaced fuel pump, primer bulb, plugs, water pump, and I just cleaned the carbs..(which looked clean to start)..I'm really frustrated...When in nuetral it will rev and everything just won'
t go under load....Everything seems normal in neutral idle, sound, everything...Whats the deal? all hoses are good no leaks or collapsing...help
