Motor has been running fine.But just recently the motor started drawing oil from the reserve tank and not the oil tank and the beeper sounds. My Oil tank is full of oil. i have filled the reserve tank made sure the cap is tight. But once i start going for about 15 Min the oil beeper sounds i stop check the reserve and it is down about a half inch and i and oil. It is not drawing the oil from the oil tank whick is full i bleed the lines still no luck. Any suggestions?
Thanks
Thanks
