I have a 1979 mercury 140 outboard I just bought. I went thru the fuel system, carbs, 125psi compression...etc. Hooked up the muffs, fired it up... ran fine....was peeing water and would rev up so I thought I was all good. Took it out on the river... fired it up... soon as I tried to throttle up... blah.. would not rev past about 2200. Had to throttle down and idle back. Checked spark and all 6 have a nice spark. I was told the ignition boxes can cause this.
Anyone else run into this? Can I test the boxes myself? How about the stator?
Thanks a lot!
Thanks a lot!
