Re: Replacing Ignition Switch for 1961 Mercury 800 6 cylinder
Hey, I was looking at the old posting and realize now that you have a Full Gear Shift (FGS) 800, not a direct reversing. The FGS would be hooked up a bit different than I described!
It sounds like you've got it pretty much figured out, but I thought I'd post this link anyway, maybe it'll help:
http://www.maxrules.com/oldmercs/Wiring/0_1965a/7.pdf
On your choke, all you'll need to do is tie one end of the separate pushbutton choke switch to the source of switched +12V, and the other wire off the switch goes to the choke wire in the harness.
And of course the ign is still energized in the "ON" and "START" positions.
The starter wire terminal might be "S" for 'starter' rather than "S" for 'switch'. An easy way to check this is to connect one end of an ohmmeter to the "B" battery terminal, the other to the "S" terminal and move the switch to the "ON" then "START" position. You should only get continuity (Zero Ohms) with the switch in the "START" position if that's the purpose of the "S" terminal.
You can do the same thing with the other terminals on the switch to make sure they're what you think they are.
Here's something else strange on these motors, some did use a wiring configuration like the one linked above; others used the later "Merc 1000" etc type of wiring, which actually is a better setup. The older-style harness/switch was connected to allow the alternator wire (to the rectifier) to be 'switched'. This is not a good idea, since when you turn the ign off you've disconnected the rectifier from the stator while the motor is still turning. This can blow a rectifier. Merc figured out that it's better to always have the rectifier connected to the positive side of the battery. Whether you do this at the ign switch or by running a jumper from the rectifier to the large Red cable inside the motor, it doesn't matter.
The other thing is the way the ign is hooked up. Early models bypassed the ballast resistors when starting only, then when the ign switch is released to the "ON" position power would flow thru the resistors. This setup isn't necessary as there's plenty of ign power to start the motor without putting full voltage to the coils (which can burn the points). So, it'd probably be best to eliminate this feature as well. You can do this easily by removing the red-wire jumper between the solenoid and the front ign coil (#2).
This diagram for the more "modern" dual-point distributor ign setup shows the difference from the older FGS ignition system:
http://www.maxrules.com/oldmercs/Wiring/0_1965a/9.pdf
Anyway, sorry about the misunderstanding and hopefully the extra info helps.........ed
