fletchermerc1996
- Nov 24, 2009
- 19
Hi guys,
Just a quick question!
Recently had a water pressure meter fitted on my boat to monitor water flow through my outboard.
I had a new impeller and housing fitted about 5 months ago along with new t-stats.
The water pressure readings I am getting are roughly 2-3 psi at idle and between 10-15 psi at WOT.
The tell tale at idol isn't particularly strong, but is a steady stream at 4000 RPM onwards.
Are these the readings I should expect, or should they be higher?
Many thanks!
Many thanks!
