phoenix-Bangui
- Apr 12, 2010
- 3
I'm just at the front side of troubleshooting this, my Motor currently does not start and the warning horn has a steady beep every two seconds. Would like to get the basic on the horn first.
1. The steady beep indicates an overheat condition, is this connected strait to the thermostate or does it run through the ECU?
2. Does the thermostate fail to the open or closed position, meaning could I troubleshoot this by jumpering or disconnecting?
3. Does an overheat create a lock-out condition with the ECU so you cant start?
I just got the colored wiring diagram this morning on PDF so I will be digging more tonight, but these three questions answered should get me started. I will be checking for spark and verify that the horn is not low oil condition. Both oil tanks are full and again it's a steady non stop beep (every 2 seconds) and what I read 4 beeps is oil.
