bassfan2326
- Mar 29, 2010
- 2
Hey there, new to the forum so forgive me if this is in the wrong place.
I have an older 30hp Japanese Mariner outboard that I need some help with. I have yet to find a good diagram of the carb so I am trying by trail and error some tweaks to get it to run. I know where the idel screw is but not sure about the air/fuel mixture screw is or if any high/low speed jets are. The smoke is quite white/blue-ish in color and it smokes quite a bit. I know 2-cycles do smoke some but I was wondering if this amount was being caused by a lean running condition. Also, the last time it ran decent, you had to "baby" it once you put it in forward or it would not take the gas and bog down; however, if eased through, it would go just fine. Now, it does not crank and idel at all. Any tips/help with this carb would be great and I send my thanks in advance.
