Starter Problems 50hp Mercury outboard
JBAuch
I have a older mercury outboard 1982, 50hp. When the starter engages the fly wheel, it cranks over just fine, but just when it starts to fire up the starter kicks out. After a few times of this, it finely starts up. Could someone tell me what part might be going, or should I replace the starter.
verado7
Re: Starter Problems 50hp Mercury outboard
your starter is working as normal - and forgive me if i sound rude but based on what you posted ,i would highly reccomend you take it to a mechanic or start learning some mechanics -sorry if it sounds un-polite but you need to have some mechanical knowledge to benefit from any info given here .
Nigelbb
I am having similar problem did you ever find out what the issue was for everyone elses sake on this site?
thanks for any feedback you can give
The starter is designed to kick out, when the motor fires. In this case the motor is firing, but not sufficiently to start. Usually this means time for a tune up.....
