I just bought a 2007 boat with a 50 hp mercury 2 stroke and it is like new. the 20 amp fuse on the motor keeps blowing when I trim the motor while in the garage. It will move up and down fine and then all at once it stops moving. I twill do the same thing from any of the three switch location that i try it from. The motor switch, the throttle/gearshift switch, or the bow switch. I have done a basic look over the wiring and find no obvious shorting connectors or wires. the trim lock pin on the motor is pulled out so that it is not inter ferring with the motor operation. Any help would be appreciated... I drove 6 hours both ways to pick it up. Therefore i cannot just take it back to the dealer and says fix it. I just purchased it Friday March 12th.
Thanks,
Jon
Thanks,
Jon
