i have a 1994 15hp mariner. does not pump water. i replaced with a new water pump kit. impeller,seals, etc. still will not pump water. i even removed the thermostat and still nothing. got any ideas?
Pull the hose off on the outlet where the water comes out of the motor, you could have rubbish blocking it, you may need a piece of wire to pry out little stones etc, had to do it on my last motor often especially when you hit shallow water where you stir up the bottom.
