I have a 2004 merc 4 stroke carb motor . It is not charging the batt, i started the motor and checked voltage to the battery cables with them unhooked and the motor is only putting out 9 volts back to the battery.
I am thinking it is the rectifier. I do not have a manual for this motor so I am looking for either some advice on test procedures ,wire colors to check for output voltage from the rectifier. What is the rectifier output ? Could this be the stator . The engine runs fine.
Thanks for any advice
Danny
Danny
