Re: what power head will bolt up to my lower unit
What Fb says. Any will bolt up and work but tha one thing you need to look for with any choice you make is the exhaust openings on your block/adapter plate and tha replacement block your gonna use. Your block has tha large, rectangle shaped holes. Tha earlier 2.4's will probably have smaller, almost square holes. You can use tha mismatched openings with a little work on tha block and tha good metal reinforced powerhead gasket. You can run it with mismatched holes without doin' anything with the above gasket and it will last a long time. Just better ta match 'em if possible. Another solution is to use tha replacement motor adapter plate (both pieces) if it has tha smaller holes...................
