Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
1990 Mercury 25 hp water pump
  • 1990 Mercury 25 hp water pump
    To my knowledge the water pump impeller has never been changed on this 1990 - 25 hp-2 cycle motor. It seems to be working fine. Is the impeller something that should be changed periodically as preventive maint.?
    Thanks for your help
    Re: 1990 Mercury 25 hp water pump
    Urr, yes!
    When the impeller dies, the engine dies.... Keep your engine healthy by servicing the water pump (changing the impeller) at least every 2 years....
    Chris.........
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    The world takes on a whole new perspective when viewed from 100’ below.
    1972 Bertram ‘Bahia Mar’ 20
    2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
    (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
    • #3
      Thanks - I figured as much. Any tricks that might make changing the impeller easier?
      • #4
        Use the genuine manual... Don't have one? download HERE. Password for the file is ribforum. I know that manual is for 1994 and up, but the engine hasn't changed dramatically between yours and 1994. The procedures are exactly the same...
        The manual explains exactly how to do it.... Just watch out for the little washer that falls off the shift shaft as you pull the gear housing out. ...
        Chris........
        • #5
          Thanks much for your help! That should make the job considerably easier. Heading North for a fishing trip and wouldn't want it to die in the middle of my trip.
          Again, Thanks
          Back to Top
