Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
cylinder bleed hose routing?
  • cylinder bleed hose routing?
    I have a 1971 tower of power 1350 and am wanting to find out if the cylinder bleed hoses are routed in to the correct location and that the check valves are in the right spots. 3037534 is serial number. I will try and describe what I have going on now the best I can.
    There is one line running from the upper main bearing to the port between cylinders 2 & 3 with only a check valve in the port between 2 & 3.
    There is one line running from the port between cylinders 4 & 5 running to the balance tube/reed block fitting on cylinder 5 & 6. With only a check valve at the port Between cylinders 4 & 5.
    There is one more hose running from the lower main bearing port to the balance tube/reed block fitting on cylinder 3 &4. With no check valve at all.
    There is also hoses also running between the balance tube/reed block fittings as well.
    Let me know if this sound right I have looked at the parts brake down for this motor on the various mercury parts stores and suspect the lower two hoses are crossed because the lengths they give for the lower two hoses are to short for the way it is routed now and it appears that there should be a check valve in the lower bearing cap port.
    Also if it needs to have a check valve at the lower main cap port what will it hurt if it is not there? And Where Can I find a New one, They are no Longer available from mercury.
    Thanks for any help.
    Re: cylinder bleed hose routing?
    I don't have a diagram, but I have looked at the parts listing and believe that you should have a hose that runs from top to bottom, with 2 tee-pieces running to check valves at the centre bearings. Centre bearings are between cylinders #2 and #3 and cylinders #4 and #5.
    There should be a check valve at the bottom too.
    Don't know where you'll get new check valves. You need the valve at the bottom. If it's not there, then no oil will be pumped to the top bearing.... Not a good idea.
    Hope this helps...
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    The world takes on a whole new perspective when viewed from 100’ below.
    1972 Bertram ‘Bahia Mar’ 20
    2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
    (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
    • #3
      Here is link to see how it goes,its in the upper right of diagram..
      http://www.mercruiserparts.com/Show_...KCASE+ASSEMBLY
      When in doubt,Trim it out!!!
      Business Owner & Certifed Technician
      Boats I own & use
      20ft Javlin w/250 Junkrude
      17ft Bullet w/200 Merc (SOLD!!)
      13ft Allison w/150 I-6
      17ft Hydra-Sport 175GT
      15ft Allison w/75 Stinger(project)
      14 x 48 Drifter with 1100SS Merc
      • #4
        Thanks Faztbullet and achris. I have studied that diagram and am not sure about the routing still. It is the lower two cylinder bleed hoses I am confused about
        Right now they cross and the fitting at the 4 & 5centre bearing has a check valve like the diagram shows and the hose runs to the fitting screwed into the port at the 5 & 6 reed block.
        And the Fitting at the Lower main bearing has no check valve (unlike the diagram) and runs to the fitting screed into the port at the 3 & 4 reed block.
        I’m thinking the bleed hoses should not be crossed like this and the fitting screwed into the 4 & 5 centre bearing should be routed to 3 & 4 reed block and the fitting screed into the lower main bearing should be routed to the port at 5 & 6. I believe this because it makes more since for the length of hose they recommend in the diagrams hose description.
        Also on the fitting that screws into the lower main bearing cap it shows it to have a check valve in it in the diagram. however I have removed this fitting and can see daylight though it so there is no sign that ever was a functioning check valve.
        So I am wondering if someone intentionally removed the check valve and crossed the bleed hoses for some type of fix or if they were originally crossed with no check valve and the diagram is wrong, or if how it is now is wrong and it was mixed up by someone else in the last 40 years.
        Thanks for any help
        • #5
          Anyone ? Ideas? or dose it really matter much on the location of the lower hoses? The upper bearing is fed by the 2 & 3 bearing port that dose have a check valve to pump the oil up to it. So I am thinking the lower hoses just pump the oil that settled to the bottom of the cylinder pairs back to the inlet of the reed block so it can be redistributed and they should be hooked up with the 4 & 5 bearing port to the 3 & 4 reed block and the Lower bearing port should be going to the 5 & 6 reed block.
          Also thought i would let anyone elce here looking for a flywheel removal tool the one sold by heartland products works grate. I just removed mine and it was seized on. It actualy tore some meatal off the crank when it pulled it off.
          Also I wanted to make shure all the crank seals in my motor are facing the right direction. All three of them the upper one and lower 2 have the lip facing down. Is this right?
          Thanks Hoppy
