I have a 1991 mercury 25 h.p. ser. no. DO27122 that I just purchased, It was not idling smooth I've clean, rebuilt carb. and fuel pump changed spark plugs and fuel filter with no change. It whats to die and I push the prime button and it will regain its idle, I've adjusted the screw on the top with little or no change it will not run smooth and it seem to be idling to low also. can anyone help. There is 130psi on the top and 125psi on the bottom piston. Any help out there
