50hp vs 60hp litttle help
hullbilly
Hi there every one was woundering if sum one could tell me the difference between an 50hp 2 stroke mercury and the same model in a 60hp?its a 1997 merc elpto. Is it possible to make my 50 a 60 with sum minor changes or not? and if so how and where can i find the part or parts? thanks for your time.
Faztbullet
Re: 50hp vs 60hp litttle help
Same exact engine ,the only difference is the carbs. The 50 uses a WME-43 series and the 60 uses a WME-44 series, the difference is the venturi size(throat) of carb thus the larger main jets
hullbilly
hey thanks for the info will see bout trying to find them do you think its worth the trouble?
tannedman
IS it worth the trouble well your only going to gain at most 5kms an hour i believe and use more gas plus the cost of the parts and the headache of tearing apart and putting back together. Remember you might only save a couple mins running time on the water
twin 50
hey, Do you think it's worth the effort if I was running twin 50hp?
Cheers,
Andy
