Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Mercury 150 Black Max Power Trim Problem
  • Mercury 150 Black Max Power Trim Problem
    Hello:
    Im trying to repair my Mercury Power Trim. It is 3 rams, Design I, Square motor 3 cables. Sometime ago the oil reservior got broke and saltwater entered to the system. The oil color turned pink. I flushed the whole system including disassembly the cylinders and pressure release valve. Now the Power Trim is working with dificulties. The up movement takes a lot of time but it do the job. The down movement is performing as normal, I think it is due to the engineís weight. The system doesnít have any external leaks and the engine donít get down unless the down button is pressed.
    I think the motor and pump are good because the unit moves full up and down.
    Can any of you please let me know if there is an schematic or a drawing where the internal parts are explained (part list). I would like to know if there are internal valves or springs that can be stocked.
    Mercury 150 HP Black Max S/N 0C27152
    Thanks to all
    Re: Mercury 150 Black Max Power Trim Problem
    Here ya go, zoom in on it to see the parts more clearly --
    • #3
      You can use this link to Merc's parts ite to view an exploded view of the parts.
      http://www.mercruiserparts.com/selec...oc_nbr=V%2D150
      Are you certain that you have bleed all of the air out of the system?
      Is there an obvious difference in sound/pitch of the motor running faster in the up then going down which would indicate excessive clearance (wear) of the pump from the water.
      • #4
        Thanks a lot. I wrote design II by error. Can you please send me the drawings of design I?
        Thanks again,
        PRdiver
        • #5
          Thanks a lot very usefull site...
          • #6
            Hi..
            normally the tilt unit is a gear pump which is bi directional with two loading valves in each direction which the pump pressure has to over come, and they will be some non return valves also, assuming all the air is out you may find that one of the loading valves is passing or not opening properley , sometimes they are reffered to as check valves also.
            rgds
            bob
            • #7
              Originally posted by Boblester40 View Post
              Hi..
              rgds
              bob
              Thanks for your post. I will try it.
              • #8
                Recently I tryed my pump/motor assembly in another power trim/tilt assembly. The problem is exactly the same. Fast going down and slow and noisy when moving up. This told me the my pump is bad. Does anyone of you know if I can repair the pump's internal valves? Any schematic?
                Thanks in advance,
                PRdiver
                • #9
                  One friend of mine borrowed me another Power Trim Assembly. I installed my motor/pump assembly on it and then the problem was exactly the same. So I concluded that my pump was bad. I ordered a new motor/pump assembly, installed it and now the Power Trim is working fine.
                  Please use this post in case you have the same problem.
                  Thank you all that helped me with your replays.
                  PRdiver
                  • #10
                    PRdiver
                    I apologize for starting a similar thread but have followed up on it with pointing to this one.
                    Now, I have a problem removing the motor. There appears to be two bolts that use a 3/16 size hex drive to remove the motor, The one on the outside is no problem but how can I get to the one on the inside without lifting the entire Mercury engine off the boat with a crane? Anyone know? Sure would be nice if there was an easier way. Is there a special tool? Thanks, Mike
                    Boat 1989 17.5 ft Glastron Sierra
                    Engine MERCRUISER Alpha 1 3.0 Liter GM 181 I/L4 SN 1A009382 mfg 10/09/2006 mod # 4111221UT Outdrive SE106 Alpha 1 Series 1
                    Prop Solas Amita 1511-145-19 14.5 x 19 pitch 15 spline rotation standard clockwise
                    • #11
                      Not getting much help but then I realize I am not that important. I took some pictures of this part.
                      Click image for larger version
ID:	174524Click image for larger version
ID:	174525Click image for larger version
ID:	174526Click image for larger version
ID:	174527Click image for larger version
                      A. How does it come off easiest way?
                      B. Is there a bolt in the back catty corner from where you can see the bolt was removed at the base in the left front OR NOT.
                      C. What if the top rear bolt was taken off, could this be removed that way? ( It is somewhat rounded and very tight at this time )
                      D. What is the cheapest way to replace this? Re-build? Used part? After market part?
                      Thanks
                      • #12
ID:	174531Click image for larger version
                        Where the red arrow is, that is where I think there may be a bolt like in the front that is hard to get to. Also the ser number plate is shown for this Black Max XR4 150 Mercury OB.
                        • #13
                          Well the unit would have needed this part or some other aftermarket product but we got it out with a flex hex drive tool and had it rebuilt at an electrical alternator/starter local shop for about $65.00.
                          Mariner, Mercury Marine Replacement Power Tilt and Trim Motor 6279 - Arco - iboats
                          I am going to say that I am somewhat disappointed in the lack of help here on this problem but hopefully my posts will help someone else some day.
