Hi Guys
I have a old but little used '69 Mercury. I bought it 2nd hand (cheap) and finally got it running today..... well sort of!
I could not find any "pee" hole anywhere on this engine.
In the end I rigged up a hose to the "Flush" inlet and water comes out of the middle of the prop, and a small hole on the RHS under the horizontal blade on the skeg. This would be underwater in normal operations.
When I start the motor this way, it doesn't run too long and oils up the plugs. This is understandable as it running stone cold.
If I put it in a drum of water, I still get no other water coming from anywhere. Which leads me to think that the impeller has gone anyway.
I have looked and looked but I cannot see any pee hole at all.
After running the motor in the drum of water for only 3 minutes it starts to get quite hot.I didn't want to risk damage and turned it off.
There doesn't seem to be anyway of accessing the lower part of the gear case, there are no bolts at all.
Is anyone familiar with this model?
Where is the pee hole, or doesn't it have one?
Is the impeller change a big job?
Thanks
Thanks
