fletchermerc1996
- Nov 24, 2009
- 19
Hi guys,
So my outboard is in the workshop being looked at. It turns out the gearbox is on the way out. The mechanic says that the dog-clutch and gears are rounded and worn on the edges, due to wear and the problem will only get worse.
They have suggested that I have the gearbox replaced or more ideally, consider trading in my outboard for a newer model.
The engine is a 1994 model and generally runs fine, although it was rough running the last time we used it, and a suspected carb problem was diagnosed.
We started having problem going from forwards to reverse when we bought the boat a few months ago. It really 'chatters' and grinds when moving into gear in both directions. To begin with, we hoped it was just an adjustment problem, but it turns out it is more serious.
The carbs also need sorting out at the same time.
So, to the questions: Am I really wasting my money and time, spending money on a new gearbox, on a 1994 outboard?
Are engines of this age generally unreliable and a financial drain?
The engine had a considerable amount spent on it before we bought it, including:
6x pistons
1x gasket set
2x main shaft bearing
6x piston bore
I'm just not sure whether it's worth sticking with it...
In reality, I don't have the funds available to spend thousands on a new outboard, so looking for the cheapest option for now.
Hope you can give me some tips and advise, on the safest and overall best option.
Many thanks for reading!!
Fletchermerc1996
6x pistons
1x gasket set
6x piston bore
Fletchermerc1996
