Guys,
I've had this motor for about three years now, and the entire time I've had an issue with the engine having a rough idle and "sneezing". Today I started the engine for the first time in about three weeks, since it's been impossible to make time for the boat with the holidays, rainy and windy weather, as well as the blizzard that we had last week.
Anyway, I started the boat, and ran it at a higher rpms (about 2,200) for about five minutes, and then backed the throttle down to the normal rpm range when the throttle "clicks" back into the middle position (ie....so that i could just push the throttle forward, and get into gear, or back, and get into reverse). As you can see from the attached video, the engine likes to sneeze and cough a lot. (Sorry that the video is sideways. For some reason, my cell phone makes the video fine when viewing it on the phone, but rotates the image 90 degrees for youtube).
http://www.youtube.com/watch?v=Ib8DfHe0KWU
This idling is the same whether it is warm or cold outside, and regardless if I've run the boat already that day, or the boat has been sitting for three weeks. Someone suggested a "lean idle sneeze", and someone else said that the fuel pump might not be supplying enough fuel at lower rpms.
I really appreciate anyone that watches the video, and let's me know what they think that it is. There are two other videos that I posted from today, but they may or may not be viewable on youtube. I had some issues, but was finally able to see them.
Thank you.
Thank you.
