bryanwess2000
- Jul 16, 2008
- 240
This motor came with a junk boat on a trailer I wanted. I tested compression
all 6 are 120-125lbs. I hooked up the wires on the switch boxes then
checked spark at 7/16'' and only 3 and 5 were firing. I swapped the # 1 and
5 coils and #1 was firing but then became intermittent # 5 didn't fire after
the swap. I tested the rectifier and it checked out ok. I tested all the coils
between the positive terminal and the plug boot and all read .90-.92 ohms
except #1 before i swapped them it read .82 ohms. The test between the
positive and negative read 0.0 on all.
The lady I bought the boat from said the stator was replaced due to hard
starting, it ran good for three weeks and developed the same problem. Her
mechanic said it needed another stator. It looks like the stator, at least one
switch box, and rectifier were replaced as well as a couple clip together
connections located between the coil packs. The coil packs and trigger
look original.
The boat doesn't have a kill switch lanyard which I thought was odd. The
motor would crank and run for maybe 10 secs occasionally so there may be
some weak spark on other cylinders. I need help on what to check next to
diagnose the problem, and any test equipment I might need. All I have is a
digital multimeter. I have a 1991 90hp that I could use the coils off of but
do not want to risk ruining them .
look original.
