garygarris
- Dec 1, 2009
- 2
I need some help and I cant be the only one whos seen this problem. Here's what I know. I have a 1995 200 xri on a Gambler bass boat. The boat on occasion is having a problem staying started. I just had the injetors cleaned and I know it has good compression. When it does get started I can run normally most of the time but other times the motor looses some power while running. I can still stay on plane but power cuts significantly. There are times when I am loading the boat on the trailer or trying to get on plane and it loads up. Almost as if it looses 1 or more cylinders. Any thoughts? My problem is I cant "break" it enough to get my mechanic to fix it. Thanks in advance.
