Hello All,
We have had this problem no spark problem for awhile, the trigger we found what was the no spark problem since it was broken in two. My big question is that I have been reading that since he removed the flywheel we should of marked the flywheel so the timimg will be the same. We have not moved the shaft were the flywheel mounts to but we will have to remove the shaft in order to install the new trigger. Any help here would be GREAT !!!
Jawzman
Jawzman
