Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
1980 Mercury 115 - Trim fluid?
This topic is closed.
  • 1980 Mercury 115 - Trim fluid?
    Hi everyone,
    I am getting conflicting reports on what I should be using for trim oil. My Seloc manual is saying 10W30? I very sure that is not what is in there right now. (It appears to be red)
    Also, it is my first year with this engine but the power trim was rebuilt last winter. Besides topping up the fluid level is there anything else I should do during the winterization or spring tune up procedure?
    Any advice is greatly appreciated.
    Thanks,
    Russ
    Re: 1980 Mercury 115 - Trim fluid?
    Your motor should have trim cylinders mounted outside of the transom bracket, and a pump mounted inside the boat. They take 10w30 motor oil. Often people put the wrong fluid in. It would be wise to purge the old out and put in the correct oil.
    As for winterization, stabilize the fuel, run the motor to get the stabilized fuel into the carburetors, fog the engine, grease the fittings,and change the gearlube.
    • #3
      automatic transmission fluid is what I use,,not motor oil,,totally different composition
      Dusky 19 - CC - 150 Mariner - Rolls axle trailer
      up right and breathin,,,woohooooo
      • #4
        They originally came with 10 or 20wt motor oil. You can use any low viscosity motor oil, Mercury's Power trim and Tilt fluid or hydraulic fluid. OMC used Dexron ATF. Many trim units have been refilled with ATF.
        I would recommend using the Mercury PTT fluid or 20wt motor oil.
        If you decide to go back to the Merc stuff you will need to drain, clean and refill the entire system. You can use mineral spirits to clean the system out.
        Merc recommended against using the ATF something about seals. I have known of many units using the ATF with no problem. So what you do is up to you. You should be OK with either fluid.
        You let the factory smoke out of it. All products have smoke installed in them from the factory. You can not purchase this smoke. The problem is, when you let the smoke out of it, the part is ruined and you have to get a new one. I wish I could find a place that sold the factory smoke.
        Never argue with an idiot. They drag you down to their level, then beat you with experience.
        3 X APBA Formula V Nat'l Champion
        APBA Formula V US-1
        It took me 29 years to become an overnight success.
        • #5
          You camt gey 20w oil. I've been looking all over for my power trim that specifies it. Dont know what to use. The shop that re filled it told me atf but the fluid is brown (oil) amy ideas
          • #6
            Stop posting in old threads. Start a new thread by looking at the Help Tip on top of the page.
            You can find 20W all over the place if you look.
            BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
            Please, no PM's (Private Messages) regarding boat/engine problems.
            That is what the forums are for.
            Only forum/moderator issues will be answered in PM's.
