Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Motor revs fast, prop turns slow
  • Motor revs fast, prop turns slow
    I have a 1978 200 hp Merc. I was cruising at about 30 mph when the motor started to rev higher, but the boat slowed down. I could get the boat to go about 2-3 mph at about 1,000 rpm, but it wouldn't go any faster at higher rpm's. What is the probable cause of this?
    Re: Motor revs fast, prop turns slow
    My thoughts are for you to inspect the bottom end. Start with the prop itself.Make sure its not stripped on the splines, and the hub is ok. If that is ok, go to the gear assembly. Last and most likly least would be the driveshaft.
    • #3
      If you have a spare prop, put it on and retest the boat.
      Chances are the rubber hub between the prop and its inner splined collar, is slipping and due for a replacement hub to be pressed in by your local prop shop.
      • #4
        spun hub
        • #5
          Thanks a lot. This makes sense and should be easy to fix.
