Morpheus78
- Jul 20, 2009
- 29
Here is the second issue apart from my idle issue. The boat seems to only have 2 speeds... slow and really fast. Its hard to get the engine to stay at a medium speed. I can get out of the canal doing 5 mph, then ill increase the throttle and the handle seems like it gets stuck and you have to give it some UMPH! to move the rest of the way up. The thing is...once you move the throttle just a hair above the point where it gets stuck...its like the engine is almost at full throttle. I tried to adjust the throttle, but it hasnt really helped. Was told i might need to change the throttle cable. Someone else said it might be something electronic that is doing it, but i forgot the name...they said the old Force 125 hp used to have a problem like this and it was an electronic/ignition issue? Any help is appreciated. Thanx
