My son was given a 1988 Ranger bass boat with a 1988 175 HP Mercury. The motor has not run in two years since it had a few wires catch on fire. After inspection, all the wiring was there but some insulation had melted. I repared it and when I tried to crank it was hard to turn over by hand (with 3/8 ratchet). With two cars trying to jump it, the engine would just bearly turn over. With the plugs out, it turned over much easier. I have spark, but with the plugs installed, I can't get it to turn over (very slow is all). I've even tried to see if it will fire with half the plugs out. It still won't turn over like I thought it hould. Also, when I first started to crank it, I used the key and then it stopped working so I jumped across the solenoid. The best it ever did was after I put gas in the cylinders, it "popprd" once. That was it. What do I try next?
