Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
9.9hp 4 stroke leaking from carburetor
  • 9.9hp 4 stroke leaking from carburetor
    My 1998 4-stroke mercury 9.9 hp outboard leaks fuel from the carburetor. When running and when primed with a bulb the leak occurs at the top of the carb. Could this be a stuck float, can I clean or do I need to disassemble?
    Re: 9.9hp 4 stroke leaking from carburetor
    Usually when a carb is leaking fuel it is due to the needle valve not being able to close all the way. This is either because there is something stuck in the needle seat or the float is not able to push the needle far enough into its seat to stop the fuel flow when the bowl is full. Usually a good cleaning of the carb, especially in the needle seat, will take care of an obstruction. If it is due to the float, you should get a new float and might as well at that point just rebuild the carb to prevent any other near future issues with it.
    • #3
      get an overhaul kit and rebuild the carb ( very easy with basic skills/tools) chances are the needle isn't seating anymore and i would do it sooner than later - you could get stranded or worse start a fire .
