I recently purchased this motor and a Seloc repair manual. I cannot disconnect the shift linkage to remove the lower unit in order to change the water pump impeller. I removed the three lower unit bolts and the lower unit drops about an inch but no more. I cannot see a bolt, clip or any other means to disconnect the linkage. Does anyone have information specific to this motor?
