Mercury 4 stroke efi 60 hp, I believe the year is 2002 / 2003. Family engine 3m9xm.9952ge
I put the boat in and it seemed to run ok. Then the other weekend I had the boat loaded with people and it seemed like it did not have a lot of power. I brought the boat back to the dock and added some fuel injector cleaner, seemed to help, rpms came up higher (poonton boat). I did notice that the volt meter was barely above 12 volts so I think the voltage regulator is acting up. I changed plugs and a fuel filter (just changed the filter and bowl, not the upper half since I did not want to remove the hoses).
I have a battery charger to ensure the system is getting 12+ volts.
Motor will idle for 15 to 20 seconds then start getting rough and dies. Motor will not allow me to go above idle. If I try to go above idle, motor will die.
I did notice that the level of fuel in the filter is only 1/4" above the bottom of the filter. This may not be an issue since the fuel is pulled from the bottom.
It sounds fuel related.
I did add new fuel earlier this year.
Any help would be appreciated.
