Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Mercury Classic 50, 45 hp, 87-89 year
  • Mercury Classic 50, 45 hp, 87-89 year
    serial # 0C145238
    I noticed water coming out of COVER ASSEMBLY, Cylinder Block by #1 spark plug. the previous owner had applied silicon where the gasket was leaking.
    while removing it i broke a wire coming off some type of sensor located next to plug #1 the cover has an opening made to fit around the sensor and plug #1.
    Could some one please tell me what is the name of the sensor and what does it do, i grounded the wire with motor on and it kept on running,, with motor off and ignition key on and i heard something making a very slight noise when i grounded the wire...... also i think the motor is an 89 but would some one know from the serial # what year it is??
    thank you
    joe
    Re: Mercury Classic 50, 45 hp, 87-89 year
    Hi,
    That was your over heat sensor.
    This is free internet advice.
    Have Fun,
    corm
    • #3
      That's a really late 1989 model. Must be one of the last 45hp motors built.
      Sensor is your temperature switch. There are two versions, each are about $50 to replace:
      96829A 1 260° Tan
      16775A 2 300° Tan/Green
      When grounded, you should hear an alarm.
      '93 Chaparral 2370 (current) '86 SeaRay Seville 195BR (sold)
      '72 Glastron GT160 & 1985 Merc 150HP V6 (project)
      • #4
        I can't thank you guys enough, great info and fast..... You guys are great.
        joe and carolyn
        • #5
          Great Info here thanks for the replies you give the people
          Verlon E. Lawrence
          Professional Catfisherman
