Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Mercury vs. Mariner what is better
  • Mercury vs. Mariner what is better
    Im looking for a used engine and am wondering which is better
    also was told that force and mariner are the same exact motor
    is this true? doesnt force really suck? if so do mariners suck?
    this is all stuff overheard Im seeking the truth!
    help!
    Re: Mercury vs. Mariner what is better
    I bought a used 25hp Mariner. It's a 1983 made by Yamaha. We did a compression test last year 125 in each cylinder.
    • #3
      My understanding is that all the Mariner motors were exactly the same as the Mercurys
      However the.Force are recycled Chryslers with a few improvements added by Merc.
      Mariners aren,t as expensive used because of the suspicion that they are a lesser line like the Force .
      • #4
        I can only speak to what I am familer with, Since the mid '80s I have owned several Mariners and a few Mercs, all 150hp or more. The parts will interchange within the model year and HP range, I currently have a Merc power head on a Mariner lower unit.
        I suggest you judge the engines per each and not as brands, they are both good stuff.
        • #5
          mariner and force?
          • #6
            I have never owned a Force nor a Crysler. Suggest you stay with the "M"s.
            • #7
              are the "M's" the same motor?
              Merc=Mariner?
              interchangeable?
              built by same?
              same thing diff label?
              • #8
                Many models of the Mercury and Mariner are indeed the same unit with different decals.
                There were a few models that the Merc used the larger diameter gearcase while the Mariner used the smaller gearcase. The smaller gearcase Mariner had less drag in the water and would out perform the similar Merc, BUT, some of those smaller gearcases didn't last as long as their larger Merc cousins.
                • #9
                  Earlier Mariners were made by Yamaha. Not as good of a reputation as the later Mariners that were made by Mercury. My 1993 Mariner was identical to a Merc except for the colors and decals. Think the switchover was early 90's.
                  • #10
                    Older Mariners=yamaha?
                    Newer Marinrs=Mercury?
                    since when?
                    • #11
                      Since about the late 80's or early 90's.
                      Don't believe it, do some research.
                      • #12
                        The small twin cyl Mercs and Mariners were indeed Yamahas for many years.
                        • #13
                          Merc XR series also had the small gearcase. Well maintained and lubed, they last a long time. Overpower and surface them, better keep spares.
                          • #14
                            j martin
                            did not understand what you meant.
                            is that some code talk ir shop talk
                            im a rookie
