I have a 2002 Mercury Bigfoot 25hp 4-stroke motor on my 21' pontoon boat. My first boat.
The boat ran okay last year, but was finicky at startup, and for some reason, would never rev past 3k rpm.
I put fuel stabilizer in the tank, ran it for a half hour or so in the fall and winterized it. This spring it will not start.
I pulled the carb off (Keihin, which I'm having a hard time finding info on), cleaned everything as best I could, and noticed that everything seemed fairly well in order; float moved freely, no gunk in the needle/seat, jet was clean, gaskets looked good.
I put it back together, reinstalled and still nothing (WILL fire off ether though). I pulled the plugs and they looked terrible; very black and sooty. I put in new plugs per OEM recommendation, and got a little bit of a sputter.
Where things stand right now.....on the carb, there is a vertical shaft that looks like it acts as an accelerator pump. When I move the likage, that shaft moves downward, I hear fluid squirt, and when I hit the key, it fires for a second then craps out, regardless of how I run the throttle to help it take off.
Also....fuel is coming out of the carb body around that shaft; there is no gasket or anything there, which I thought was weird. On the very outside lower edge of the carb, there is also a brass screw that goes down near the float bowl (screws in horizontally from the front of the carb). When I loosen that screw, I get fuel to leak out, which tells me the bowl is getting fuel.
Can anyone recommend where to go from here?? If you'd like pics, please let me know and I can provide them.
+ EDIT +
Fuel pump IS working. Removed carb and watched while cranking the motor; AMPLE fuel from the feed line.
-adam
+ EDIT +
-adam
