Re: Mercury 35hp hole next to spark plug?
The gasket you need is 27-65490-2. You may want to consider getting that temp sensor, although they are a bit pricey at about 85 bucks. Simple job to change out the gasket,torque from the center bolts outward. Mine were 70 inch pounds, check your manual for your specs.
