Ok new at fixing boat motors changed distributor because wouldn't spark it worked and the thing runs now but have new problem fule is pooring out of bottom carb after running for 10 seconds and floods out should i rebuild fule pump and see if that fixes the problem or should i do both fule pump and carbs all at once since i cant find anyone that is willing to fix since the motor is so old..
