I believe it is 50:1. HOw does that break down on a 6 gallon gas tank? 5 Gallon? Thanks!
B BIGDOG2594 Cadet Joined Jun 23, 2008 Messages 13 Apr 30, 2009 #1 I believe it is 50:1. HOw does that break down on a 6 gallon gas tank? 5 Gallon? Thanks!
B basshunter21 Cadet Joined Apr 28, 2009 Messages 12 Apr 30, 2009 #2 Re: Correct oil/gas mixture for a 73 Mercury 650? On 6 gallons of gas it would be 16 ounces of two stroke oil
B BIGDOG2594 Cadet Joined Jun 23, 2008 Messages 13 Apr 30, 2009 #3 Re: Correct oil/gas mixture for a 73 Mercury 650? Thanks a lot, I appreciate it.
S seany150 Cadet Joined Apr 16, 2009 Messages 23 Apr 30, 2009 #4 Re: Correct oil/gas mixture for a 73 Mercury 650? i use this website, quite handy cos you can work out the ammount of oil you wanna put in first then you can get the ammount of litres required. handy if your fuel tank is still part full from your last outing http://www.csgnetwork.com/oilfuelcalc.html
