Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
How do you clean out a speedometer pitot?
  • How do you clean out a speedometer pitot?
    The speedometer on my Optimax is stuck on 0 MPH. I tried cleaning out the pitot on my lower unit with a drill bit but that didn't seem to help. Has anyone else been successful in fixing this? On past boats I have just given up and put a pitot on the outside of the boat, but this one would be harder to do because it has a notched transom so running a tube might be difficult. Thanks.
    Re: How do you clean out a speedometer pitot?
    take loose at speedometer and blow compressed air back thru it
    • #3
      My speedo didn't work until I cut a kink out of the tube I found.
      • #4
        I have a butt connector on my speedo tube near the OB. I disconnected that and blew air toward the speedo and it worked. I tried to blow out the blockage between that butt connector toward the OB and its clogged. I poked drill bits into the pitot and felt nothing.
        I cant get what ever is in the foot of the OB unclogged.
        • #5
          spend $12-15 dollars and buy a new one. The hours you spend trying to clear a failed peice of plastic are worth more than the replacement cost.
          you can even get it right here from iboats http://www.iboats.com/Teleflex_Pitot...-view_id.40246
          Thats like wiping your butt before you go. You can do it, but it just don't make any sense.
          • #6
            Moss, algae, marine growth in general, will plug up the tube in the lower unit.
            Careful with the wire attempting to poke it out often will push and compress the vegetation into a hard solid plug.
            I've found the cheap Wally World carb cleaner to work well to kill the vegetation and sterilize the tube, a shot of compressed air blown back thru the tube from the butt connector usually clears the tube.
            Add this to your list of seasonal maintenance.
            • #7
              After a while I was finally able to clear my clogged sterndrive speedometer pickup hole today (after hitting a large stick on the water) with some of the suggestions provided here and other sources. I ended up using a 1/8" and smaller drill bit and spun it by hand at first to pull the debris out of the hole. After a time with no luck I gripped the bit with a pair of vise grips to help grap the debris inside the hole (mostly wood) and continued to slowly turn and pull out the debris especially since I had no idea how deep I would need to go and also didn't wan't to puncture the gear housing. Eventually I broke thru the clog and water poured out of the hole. I blew out the hole from the top tube connection with water and air at the end. At the end I measured the depth of the cleared hole at 1-3/4" so that next time I can use more twisting force until I get near the final depth. Note: I have a 2005 Alpha 1, Gen II drive so other types will likely have varying depths. Thanks for the help and I hope I can also help someone else with this issue.
              • #8
                On every outboard and stern drive that I have ever owned, I finally give up trying to keep the lower unit pickup clear and end up putting a cheap plastic pickup on the lower transom. Works great and never clogs, but does get kicked up once in a while. People like me who do their running on the river have more trouble with this.
                Back to Top
