Re: Mercury 125 Whining Noise
a quick and cheaper check is to drop the lower unit oil and measure amount taken out and check for metal filings in it.
I've been searching the net for about a week now because my 115hp merc is having the same issues,
it is amazing how many mercs and Yams have this problem which is a design flaw, removing oil will cost
money but just dropping the leg and greasing won't as long as you have some grease.
Lift the cover off the engine while its running, the bearing noise appears to come from the oil
pump which is under the engine and below the crankshaft end.
A good test to see if it's the top bearing is a squirt of a teflon lube directly into the
shaft area, tilt the engine slightly up and have a look in the top of the cowling at the back of the engine
you can just see the driveshaft as it exits the oil pump.
Squirt a big load of teflon oil in there above the bearing casing and let it run down the shaft.
if that doesn't cure it then try the gearbox oil.
