I want to check if my oil pump is working,but need to run the motor. Is there a recommended oil to gas ratio that I can use to premix with the gas. Also if for any reason I wanted to bypass the oil injection permanently,first is this recommended,second what would need to be disconnected in order to accomplish this. Reason is that if I continue to have problems,it might be easier just to premix the gas and forget the injection system. Thanks
