This is my first post here, so first an introduction, I am from SW MI and have owned my 1988 Fisher 18FS with a 1988 Merc 115 L6 since new. I have run across this site a few times when searching the web for info and appreciate all the advice you folks give to those in need. I hope someone can help with my questions.
Last year my motor lost a couple of cylinders - no compression. Not sure exactly why, but it had problems for about 4 years and I tended to run it pretty hard. So, live and learn - and slow down. While searching for options, I ran across a used powerhead at a local dealer. The lower unit on this motor was trashed. It doesn't have a sticker, but based on the stripe colors, etc., it appears to be an identical match to mine and looks to be in good shape. They are going to pull it out of storage, check the compression and call me. The problem is they are asking $1,200 for the powerhead only, which seems a bit high. The other problem is, even at this price I don't thing I can get power on the back of the boat for less. Remans look to be nearly $2,500.
Can anyone tell me what price range one could expect for good used powerhead? Thanks in advance for any advice/experience. -Greg
