Hello every one! My engine starts and idles fine but bogs down and dies after a little bit. When this happens i can pump the primer bulb and it powers back up. I had the carbs rebuilt and the problem got worse. I have also replaced the fuel lines. What do I do next. Also, the white/black trigger wire casing is flaking of and the wire has started turning green and brittle. Obviously I need to replace the trigger but what causes this. Are there other parts I need to look at replacing. Thank you for your help.
