i am getting beeping (not continuous) when running, not at idle. no spark to one bank, 2, 4 and 6 cylinders. oil is full oil pump shaft is turning. tested oil level switch = good. switched red wire + red/white wire, blue wire + blue white wire. same cylinders out of idle.
running out of ideas
is there any common problem?
