how do you get at the power head lower gasket? i removed the power head but something is holding the plate that is on top of the lower gasket. i do not see anything else to loosen on top. could this plate somehow be attached to the lower unit? the first pic shows the plate that i need to remove (the black hole is the exhaust tube that is attached to the plate). the second pic is a close up i am pointing at the lower gasket and you can see that i can slide the plate from side to side a 1/4 of an inch. thanks for the help (i hope)
