Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
high rpm at idle mercury 200 optimax
  • high rpm at idle mercury 200 optimax
    Hi,
    Since yesterday I have a higher RPM at idle. It is a mercury optimax 200 from 2002 with 540 hours.
    You have to know that:
    • the engine was not running for 2 months
    • one of the two batteries was empty
    • it started immediately
    • after 10 seconds goes up from 650 rpm to 1150 rpm
    • engine is flushed with muffs
    • after giving more throttle and go back to neutral, the engine still runs at 1150 rpm
    Is it because the water pressure from the hose is not enough?
    Is it because one of the 2 batteries was empty?
    Is it something else?
    EDIT: on the smartcraft the sign TRIM with arrow blinks every 5 seconds...maybe this helps
    Re: high rpm at idle mercury 200 optimax
    Anyone? what can it be?
    • #3
      I have almost an identical problem.
      otherwise seems to be running fine.
      • #4
        back to the top.
        Anyone have any thoughts?
        • #5
          hello RIROCKHOUND,
          The problem is solved. A ground cable that leads to my metal fuel tank was the problem. The smartcraft computer made conflicts with that cable and so made bad signals from the engine sensors. By cutting the cable, the problem was over.
          So I suppose that also you have an electrical problem and no engine problem. Check the wires maybe?
          ciao and good luck
          Back to Top
