BIGDOG2594
- Jun 23, 2008
- 13
I took the plugs out, look to be in good shape. Nothing out of the ordinary. Took off the distributor cap and noticed that the points were corroded and the rotor was also a little corroded with a little bit of dust in the bottom of the cap. So I took my handy little dremel and polished them up a bit. Gonna put the muffs on and start it up to see if it will idle high again. Then I will pull the spark plug wires, one at a time and make sure I have spark on all three. Does this sound right? Is it possible I was just not getting a good connection on the points and the rotor and that caused my problem. Boat lacks power with WOT, but no other noticeable sounds or problems that help me go in a specific direction. Sounds pretty fine but just won't get up. What would be next to check? Compression? I can check that with a gauge and just turning the starter wheel one at a time right? Do I leave the other plugs in if and when I test the compression one at a time? Thanks in advance!
