Re: Water pump on a 1996 150hp mariner
Do a search here, there are several threads that deal w/it and some w/links to pages that will tell or show the procedure. As Chris said, realitive simple procedure. Make sure you get all the visible bolts and then one under the trim tab. You have to remove the trim tab thru the hole on top, it usually has a plastic cap on it. Use an extention w/locking type release otherwise you may just end up leaving the socket in the hole.
