Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Mercury low oil sensor question.
  • Mercury low oil sensor question.
    I recently bought a 1990 90 horse mercury with oil injection. Whenever I plug in the sensor that is coming from the oil tank, there is a loud constant beep when I turn the key on. I read where this is a low oil sensor, but I filled the tank, and it still does it. Any ideas on what might be the problem on this? Thanks
    Re: Mercury low oil sensor question.
    The magnet came off the float, you will need a new tank as it's not repairable
    • #3
      i have a 91 ranger with a 150 blackmax and has recently started beeping continously when running down the lake. i have been told its the sensor or the module. i put a tester on my sensor and seems to work but have read that the washer is supposed to be attached to the float and mine is not.what should i do and do i also have to get a new sensor for my oil resovoir on my engine? THANK YOU--superfluke
      • #4
        Its definitly a very annoying beep. An idiot light might've been better. I disconnected the buzzer. Probably not the smartest thing to do, but as long as I keep an eye on the oil level, and the tell tale, the motor ought to be ok.
        I do worry though, i've heard of the oil injection going out on these though..
        15' 1974 Canbar Crestliner tri-hull boat.
        90HP 1989 Mercury 2 stroke, 3 cylinder oil injection.
        • #5
          Yep, if the alarm goes off, disconnect the buzzer. If an idiot light keeps coming on, just cut the wire.
          When the power head grenades, it'll be the oil injection system's fault.
          Amazing logic displayed here.
          my 02
          John
          • #6
            ours was doing the same thing and it needed an new impeller
            • #7
              Superfluke,
              Please start your own thread. The oil injection systems on the 90 and the V6s are COMPLETELY different.
              Chris...........
              xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
              The world takes on a whole new perspective when viewed from 100’ below.
              1972 Bertram ‘Bahia Mar’ 20
              2006 Mercruiser 4.3MPI (0W617679) w/Alpha One Gen II (0W829301)
              (Original - 1972 '165' In-line 6. Previous - 1994 4.3LX)
              • #8
                Laddies is right. I had to get a new tank for my 40 hp Mercury
                • #9
                  my 02
                  John
                  Aw common J. Sounds like a remark I would make.
                  Mark
                  If you are new to boating or have a new boat, a knowledgeable friend could show you how to operate your boat and save you a lot of grief, maybe some money, and maybe your life.
