Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Oil for Mercury tilt/trim reservoir?
  • Oil for Mercury tilt/trim reservoir?
    Newbie here with "new" used boat! I have a 1992 Mercury 135hp 6 cylinder with electric tilt/trim. There is an oil reservoir on the port trim side, and a large screw above it. What is the proper lubricant/oil to fill this, and is there any special instructions?
    TIA!!!!
    Re: Oil for Mercury tilt/trim reservoir?
    Use type A auto trans fluid or equivalent. Be sure to trim motor all the way up and move lock lever into position before removing screw. The system is under pressure in all positions except full up.
    Hope this helps!
    Mike
    • #3
      Thank you kindly Sir!!!!!!!
