Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
optimax 225 fuel filter change
  • optimax 225 fuel filter change
    it seems easy to change out the fuel filter but mine is not moving. i used the screw driver method through the castlated top but it does not move. the plastic is starting to break. any ideas?
    thanks
    touche'
    Re: optimax 225 fuel filter change
    the filter can be removed with tool#91-896661. you can order it on line from shortsmarinediscountparts item #150241866684. good luck!
    • #3
      thanks. it is on the way.
